Steering Wheel Fit?
URL: http://www.bayarea02.com/techtips/320_wheel/index.html
The hub will fit the steering column of a 2002.
The 320i horn contact arrangement is different, so the horn button will not work without modification. See URL for more info.
If your 2002 is 74-76, the turn signal canceller will work. For earlier 02s, with the TS switch on the right side, the TS cancelling tab on this wheel will work if there is a tab on the hub that can be rotated 180 degrees or if the hub can accomodate the loose tab used on the pre-74 02s.
