74-76 Mystery Wires
chargin
Not completely sure about squarelights, but roundies fitted with 2 bbl Solexes (late 72 thru end of 73 production) came with two wires that ended near the carb and were hot with the ignition on.  One was for the anti-dieseling solenoid fitted to (most) Solexes and the other wasn't used on US spec cars.  Not sure what it was used for on Euro cars, but I used mine to power a throttle positioner solenoid that would boost the idle on my engine when the A/C was on.  If you're not gonna use it, be sure and tape it up out of the way so it doesn't accidently ground and cause a fire.
cheers
