Bmw 1600 Ti (1967) With Period G1 (1966-1969) Group 2 Fia Htp
Original -67 BMW 1600 ti with just renewed period G1 (1966-1969) Group 2 FIA HTP valid to 31.12.2020. Homologation form number 1499. With all parts complying with period specification. Valid in rally and racing. In great condition. Vin number 1581372.
Engine dynoed 160HP@7300 torque 172Nm@5800.
Cylinder head is type 118 ported to hemi combustion chamber. Schrick 316 camshaft. Heavy duty springs. Valves machined. Head flow tested 10mm lift 186hp, 12mm lift 196hp.
Custom venolia high compression pistons with valve pockets, contact reduction grooves, accumulator grooves. Compression ratio 13. Engineblock overbored 0.5mm from new block.
Polished and balanced connecting rods (all within 0.5 grams).
Balanced crankshaft. Lightened flywheel. New sachs clutch kit.
Recurved distributor. Crane XR3000 optically triggered ignition system. Lucas Gold Sports Ignition Coil.
Reconditioned 2x Weber 45 DCOE 152 with long velocity stacks. Intake manifold matched with intake ports.
Electric radiator fan.
Carter Gold Electric Fuel Pump. Malpassi fuel pressure regulator. 40l safetytank. Battery relocated to trunk.
Gearbox 4-speed getrag 232. Spare gearbox included.
Differential with ZF LSD 40% with 5.32 ratio. Complete diffs with 3.9 and 4.1 ratio included.
2.5" exhaust with sport muffler.
Chassis has a fresh polaris metallic silver paint. Lexan rear- and side windows. All undercarriage parts have just been sandblasted and powdercoated. All wheel bearings are new. All undercarriage bushings are new urethane bushings (suspension pivot bushings, inner and outer control arm bushings, radius rod bushings, trailing arm bushings, steering idler arm bushings, swaybar end links). Rear subframe with solid mounts to chassis. Differential hanger with hard bushings.
Reconditioned steering box.
New bilstein sport shocks front. Rear shocks are custom valved bilsteins.
New 240mm front discs with reconditioned calipers. New ferodo DS2500 brake pads. 230mm rear drums with custom high friction linings. Braided brake hoses front and back.
Two sets of springs. One for rally and one lower and stiffer for track racing.
Included rims: 6x 13x5.5 Minilite. 4x 13x6 ATS. 4x 13x5.5 BMW (Alpina style E21). 4x 13" original pressed-steel rims. 6x BF Goodridge ICE tyres. 6x Kumho R800 gravel tyres. 4x studded tyres. 4x summer tyres.
FIA approved full rollcage. Terratrip intercom. Tripmaster vintage trip. Silver dollar gauges with revcounter. Drivers seat Sparco EVO VTR (manufactured November 2008). Co-drivers seat OMP RS (manufactured May 2008). Sabelt 6-point harnesses (valid until end of 2015).
Extra lights with 4x Hella 3000.
Included are following extras:
New bigger vented front discs, hubs and complete calipers with bigger pistons (homologated). Two used good condition bonnets. New left and right front side panels. Spare gearbox 232. Two complete diffs 3.9 and 4.1 ratios. Two used spare engines. New exhaust header. Plus some other miscancellous parts.
Year: 1967
Make: BMW
Model: 1600ti
classifieds-41127-0-08874900-1411862895_
classifieds-41127-0-93560900-1411862920_
classifieds-41127-0-34059700-1411862950_
classifieds-41127-0-48435300-1411862992_
classifieds-41127-0-61175000-1411863017_
classifieds-41127-0-76679300-1411863051_
classifieds-41127-0-35815200-1411863073_
classifieds-41127-0-42014400-1411863098_
classifieds-41127-0-27988400-1411863120_
classifieds-41127-0-69761400-1411863141_
classifieds-41127-0-03101100-1411863157_
classifieds-41127-0-28820100-1411863412_
classifieds-41127-0-01288400-1411863474_
classifieds-41127-0-31511200-1411863491_
  • 1 month later...
  • 1 month later...
