Need Verification Of Oil Sender
jrhone
Nice! I can't stand that adaptor at the back of the head. I need to move the oil temp sensor as it's useless there too. They don't make one in an oil pan drain plug do they?
John
You can tap the oil filter housing for the oil temp sensor. I believe it has to be a tii filter housing though.
That's what I did.
OK...just installed the VDO Sender.  I can confirm that it bolts right up.  360-024 is indeed the correct sender for the VDO gauges that are 150 psi and it has a 7 psi dummy light connection for the dash light or if your gauge has a warning light.
The sender has a spade to connect the original dash light wire to? Can you post a photo of this installed?
Thanks in advance!
