Brake Pad Sizing Issues
jp02ti
hello all,
I am changing the brake pads, and trying to get upgraded to some proper pads for auto-x and track.  I'm wanting to use the Hawk Blue - feedback welcome.
here is the issue though:
the pads I have removed from the car are SMALLER than a standard 2002 pad.  they measure 77mm wide by 59mm tall.
the Mintex pads I have (NOS spares) measure 77mm wide by 70mm tall, so they don't fit, I can't slide them in far enough to get the pins through the holes.
when I look up the Hawk pads, their spec is 89mm wide and 70mm tall - which is actually for a 2002ti (or tii I suppose).  this is a bigger surface area pad then either the Mintex or the old one I removed!
the caliper itself is a 2 line 4 piston caliper on a solid disc.  when I bought the calipers 8 years ago the pads came with them, and everything bolted up nicely with no issues.
so the question is:  what the heck is on the car right now?  do I even care?  does anybody have experience with the Ireland Vented Rotor Front Big Brake Kit?  looks like it should bolt straight on to my 2002, and I should still be able to run my 13" wheels.
any insight from the 2002 masses?
thanks,
Jon
post-32072-0-01262300-1411489642_thumb.j
post-32072-0-68862600-1411489672_thumb.j
post-32072-0-92140800-1411489697_thumb.j
