No Heat, Any Tips?
It was chilly this morning, so I tried to get some heat for the first time this season. The heater motor has been out for a while, but the heat used to work, but nothing now. Any suggestions??
Its located in the vent "bucket" between the firewall and the passenger compartment. Follow the heater hoses from the engine, its the brass valve in-line. Check to see if the arm is moving.
i have to do this to regulate my heat. translated as heat is always on but in Mass in October, it's a good thing
check if it's leaking or has steam coming out of the actual valve (running, hot)for better diagnosis of bad valve or bad valve actuation
