'72 Tii Electrical Issues
Mitch_M
Help me figure this out ladies and gentlemen: In the last week or so, I've noticed that my temp gauge has been reading high, and reading higher when the lights are on (it jumps up when I turn them on). I'm pretty sure the engine is not running hot because sometimes I'll be sitting at a light and it will read about halfway up the temp gauge in the dash, which is where it has always read, and then when I put it in gear it will jump up (not gradually like the engine is getting too hot on acceleration) and then jump from the halfway mark up to the red as I drive along.
This may be unrelated, but tonight I drove over to the gym and noticed the VDO voltage gauge in the center console was reading low. I turn the car off in the parking lot and try starting it again. Nothing. I figure well the wife will be off of work soon I'll get her to jump my car after I workout. Go workout for about an hour and a half. Car starts right up. I get home, turn it off, won't start back up. Anybody else experienced this?
The only thing I've done electric wise lately is get a new voltage regulator, because my voltage gauge kept jumping up into the 14+ volts range as I would drive along. Could the new VR be faulty? Sorry for the long post, but ya'll are always so helpful. TIA.
--Mitch
check your negative grounding wires at the alt to block and block to chassis, and baterry to chasis, plus the negative leads from the back of the cluster. Often times you mau need to wiggle them at the contact point to "clean" them and or tighten. Runnig extra ground straps never hurts too.
Reason it may not be starting when hot is due to heat sink resistance in the grounding wires.
Just go over all the leads from the battery out and inspect, tighten, replace.
Good luck and BTW 14 (13.8) volts at running is normal to charege the battery.
Also Esty might snap at you to do a search so do one next time. :-)
But what do I know
And one more thing to check...the negative ground strap and its two branches--especially the skinny cable that grounds the body.  If that isn't making good contact, the only ground path is via the accelerator linkage, a pretty tenuous path. It can also cause your temp and gas gauge needles to jump, plus other strange electrical occurrances.  The ground strap that leads to the engine generally stays pretty clean; it's the body strap that's usually the culprit.
When I changed my VR, I got one that was plastic-bodied instead of metal-bodied.  That created many funky electrical issues.  I had to track down a proper metal one.  Installing that, along with cleaning the grounding point behind it, solved the funky problems.
That said, my problems were a little different than yours...but they started with installing a new plastic-bodied VR.
Scott
02ing since '87
'72 tii Euro  //  '21 330i x //  '14 BMW X5  //  '12 VW Jetta GLI
Checked the alternator to engine ground. Cleaned it. Still having the hard start issue and it's getting worse. Where is the engine to chassis ground located so I can check it?
Edit: I also forgot to mention that my battery is in the trunk (done by the PO). Don't know if that makes a difference. Also, I hate electrical problems haha.
Edited by Mitch_M
