Put in the Crane xr700 yesterday
wow what a difference. The car is running about 30 cooler and smoother; and no more popping on deceleration! Then again my poorly adjusted dwell could have had something to do with that.
I've run/installed both and of the two prefer Crane's HI-6 because it's a better value. I've never had any repair/replacement issues with either. The Crane has a built in rev limiter with no "pills/chips". And you can usually pick it up for $200 with free coil (ps 91) which is a pretty good deal.
They both are modular and accept different adaptors/piggybacks to do diff. things.
I'm currently going to run the HI-6 and use Cranes Timing Boost Retard w/my turbo motor.
Both units are reg available from:
www.summitracing.com or www.jegs.com
