When torquing suspension bolts the car has to be on the grou
in order to get proper torquing or if not you'll get improper suspension pre-loading? What's the procedure here when putting in new bushings, etc to get proper settings? thanks, Cort.
yes, it has to be sitting on it's wheels. does nto have to be ont he ground.
Get a few contrete blocks and put them under the wheels before lowering the car of the jack. That will preload your suspension and still give you access.
steve k.
...was to not just preload the suspension with the car's actual weight, but to FULLY COMPRESS the springs and shocks...THEN tighten everything up.
Good for an extra .5" to 1.0" lower.
