Can you visually see the diference between tii and stock str
The strut tube and sprinch perch are the same, the difference is in the spindle. The shape is the same in most cases (I've seen two different tii shapes although the used the same bearings) but the tii spindle is considerably larger. Those who have worked with both can easily tell the difference but it's harder to distinuish the two if you haven't worked with both.
you can tell by the caliper bolt spacing. The tii brakes have a larger spacing between caliper mounting bolts. I don't remember it exactly, so check the archives.
