Is an auto gearbox worth much?
I swapped a manual into a friend's automatic ('73 2002), and neither he nor I want the auto box. It's just sitting in my garage. I don't think it worked perfectly, but it did work, so it's probably worth saving if anyone wants it. Anyone have an idea of what I should ask for it, or if anyone is likely to want it at all? Any of you guys want it? I'm in Portland, OR.
thanks,
- Dave
hi .... i posted the message above at about the same time you posted this message.. i would like to learn how to swap the gear box.. what is the difficulty factor in tackling this type of project??
thanks cris
It's pretty easy, really. Here's what you'll need (if using a 4 speed
box like I did):
- 4 speed driveshaft
- manual pedal box
- manual brake fluid resivour
- clutch master cylinder and feed pipe (to connect to resivour)
- clutch slave cylinder and feed pipe
- manual flywheel and new flywheel bolts
- pilot bearing (automatic doen't use one)
- clutch disc and pressure plate
- manual tranny (obviously) and associated shift platform, shifter,
linkage, etc.
- interior shifter surround, shift boot, etc.
Just pull the auto tranny like you would normally. Remove the
exhaust, driveshaft, automatic flywheel and driveplate. remove
anything associated with the automatic tranny, basically.
Remove the auto pedal box. Install manual pedal box and all
clutch hydraulic hardware except the slave cyl. (clutch master,
new resivour, connecting pipes).
Bolt up new flywheel, tap pilot bearing into end of crankshaft.
center clutch disc with allignment tool and bolt on pressure plate
(use locktite).
Install manual tranny (easier said than done, I know). Install slave
cyl and connect to master w/ proper pipe. Install driveshaft. Re-
install exhaust.
I know this is incredibly simplistic, but I don't have enough time
to write it all out. For elaboration on any of this stuff, search this
site; that's how I got all my information.
good luck,
dave
...unfortunately, my '02 is in about 30 peices right now.
email me off the board to work something out - hopefully my
email is included in this post.
Are you guys still meeting at the lucky lab on every other
thursday? I came a couple of times, but lost track of which thurs.
it is...
talk to you soon,
dave
you'll also need a throw-out bearing that matches the tranny
(they're different for 2002 and 320 trannies)
Just as an additional bit of information, if a 5 speed is not
important to you, you can use a 4 speed from an early 320 as well
as a 2002. They're slightly different, but the same length so you
can use the same driveshaft. My brother has one in his '02 and it
works great. Only difference is the slave cylinder and the throw-
out bearing.
- Dave
