Kuglefischer problem resolved!....Next, cleaning the pump
Mystery oil did the trick!I let it soak for a day and then I tried tapping method using a phillips screwdriver. After about an hour of rotating the pulley and following the sequence of the two working pistons, I got piston 3 to work. Then about ten minutes later, I got the #2 piston firing. Of course I had removed all hoses to the pump, the air box, drained the coolant, removed the radiator, ...etc. with the intentions of removing the pump. I could not get the pump off because the spanner I got was too big. Even though all the pistons are firing, I still want to remove the pump and properly clean it before I put it all back together.
I will have to find the right spanner to remove the pump pulley.
I will post here when my Tii is on the road.
TBaker-74tii
1974 2002tii Riviera (favorite)
1974 2002 Chamonix (daily driver)
1976 2002 Siennabraun (parts car)
1983 320i Baltic Blau (other daily driver)
1990 535i Schwartz (wife's)
Thanks Rob. I passed your house the other day looking for a detour from the bad traffic on I-20. Saw the bike rack...... really nice. I mounted mine on the Tii as incentive to get it running!!
