lots of bodywork questions
What gauge sheetmetal should I use? Where best to get that (hardware store?)? What should I use to cut out the rusty sheetmetal-sometimes two layers thick from overlap (this is my Volvo-not the 02 thank God)? I have a Milwaukee "4" grinder that I can attach a carbide blade to but it's dangerous and not very precise. I also have a Sawzall but that seems to bend the edges and deform the surrounding material. I guess I could use a finer blade and less pressure but it seems the back and forth motion of the blade is still a problem as compared to a one way spinning action. Is there something else out there I should be aware of. Roto Zip maybe? A nibbler won't get into the tight corners btw. Any good bodywork links I should check out? I'm practicing on the Volvo and mini van before doing even the slightest bit of bodywork on the 02. TIA!
Go down to your local auto dismantlers and ask if you can cut off a door skin (or something that works for your application) from something in their crush pile.
You can use your 4" grinder for cutting the metal. Use thin cut-off wheels. You can cut 18, 20 gauge with some big tin snips, but it can be tough doing radius'I'm a rookie at it too. I got HP Books Sheet Metal Handbook for starters. Very helpful. Makes it look easy. It isn't. I bought some tools from eastwood. I have a great deal of respect for people who can bend metal, fix cars and make a living at it.
Makita electric die grinder and 3" cut off wheels for bigger areas and a Dremel and small cut off wheels for tight areas. The 3" wheels last quite a long time if you don't push the cut too hard - the Dremel wheels go away fast, but make a VERY thin cut.
If you have a comressor and air tools an air die grinder would be as good or better then the Makita, which only has one speed (about 20K rpm); another great air tool for the purpose is an air cut off saw - it's kinda like a little sawzall, but used at low speed with fine tooth blades, it'll make a really nice cut in a pretty tight radius.
If you can find any Volvos of the same 2xx series anywhere, cutting out same gauge metal to use for patch panels is probably a pretty good idea - a metal fabricator friend told me some time ago that sometimes the metalurgy is a little different between the body metal and generic mild steel sheet which can sometimes cause minor welding problems. Using metal from the same source avoids the problem altogether.
