1974 2002 oil leaks
It can be replaced with the engine in place, but you might want to remove the radiator for better access. The timing cover must come off as well so get those gaskets too. Good time to check out the water pump, alt bushings, belts, etc. At least the pully comes off easily with 4 bolts...unlike the S14's with it's big mofo 350ft.lb crank nut.
