here's a "what-if" question concerning tuning the
has anyone made a new 'cam' to address the fuel-curve block that one might run into when building a 'hotter' tii motor? somehow i doubt there are any common-knowledge equations surrounding the dimensions of the cam and it's effects on fuel delivery?
URL: http://www.bayarea02.com/features/pfister-interview/interview.html
Follow the link to the interview with Gus Pfister.
"If you make changes to the airflow then there is no way of changing the fuel flow, without changing the cam inside the pump. You can do this type of modification, (pointing to a pump he has altered for tii racer on the East Coast) but you have to realize after that your fuel map is not the optimum anymore. You can make certain corrections, but it's never going to be as good as it was designed originally."
If you made any changes, you'd need hours of dyno time to be sure you're getting the mixture you want. Several tii tuners have said that the stock Kugelfischer can deliver enough fuel for any practical level of power you could get out of a streetable tii engine.
