How do you remove factory decals?
gary there is a tool call a pinstripe eraser that is basically a big round disc of rubber eraser material. They are available with the tool that spins it (relatively slowly, not grinder speed) or just a disc shown in the pic for use with a hand drill.
can let it sit on the area for a while. ( pictured: Inka hood that was very scummed with previous glue. etc, after it soaked in Goo Gone while it was off the car during the engine swap. New insulation from Jack Fahuna installed) If you have verticle surface, you will have to saturate the decal, etc, and go after it with a scotch brite green pad. That should avoid hurting the underlying paint, and may get the decal off. I hope someone else has a more effective product that does not hurt the paint for you to use. The Goo Gone, on a verticle surface requires a lot of work. good luck with project.
