Single 38 DCOE vs. 38/38 DGAS vs. Single 40 DCOE
Has anyone tried this setup yet ? I just saw one carb of this type on eBay and would like more info. The reason being many many conflicting stories that I am hearing. It is a learning process and things I am being told are really becoming a little confusing. The debate between a single 40 side draught and a down draught 38/38 had gotten way in my head. I am 85% inclined in using a 38/38. Race setup or street setup is what I am talking about. What was the final decision..
ps. I am reading the archives also.
TIA
you do realize that all of those carb setups you mentioned are not scca legal right? They don't fit into a class as far as I know. You either go 32/36 or dual 40's. With that said I have the 38/38 setup. It is not a very elegant solution and if I had to do again, I would probably go for the 40 or 45 single w/ the lynx manifold (DO NOT GET CANNON!!!) or dual sidedraft. I still have my reservations about non progressive carbs, though.
It provided a good kick, to an old stock motor. But it certainly is not the ideal carb for the car. I think that its too big for completely smooth street driving. Maybe not enough air velocity at low rpm for the large barrels.
Its great on the highway, and under acceleration. But stumbles a bit at low rpm in the neighborhoods.
Its pluses are price, almost bolt-in (have to machine out the intake), and it can be adapted to the stock air cleaner for visual state inspections.
I would like to try the Lynx single sidedraft setup.
I will tell you this, the hoopla about a dead spot you can't tune out with the 38 is bullshit, mine runs very nice at all rpms and gets up to 30 mpg on a road trip, and in fifth gear it accelerates evenly with a lighter 02 with a 32/36 in fourth. Both cars in fourth gear, I walk away. Same diff ratios by the way. Today I am installing the dual 40 DCOE setup, but it will probably take a while to get it dialed in. I'll post my first impressions as soon as I get it running.
