exhaust manifold heat shield- will this work on my tii?
New heat shields for Tiis are still avaialble from all major '02 resourses. Rob Tores at 2002Haus got me mine a few month back. i think it set me back around $20 but i cannot remember for sure.
steve
i just put one on my 72tii and it fit fine. it's heavier than the original and has a better air flow. does someone know why the original tii heat shields should only be used? i'd like to know if there is some reason i shouldn't use this variety.
thanks.
That early manifold will work on the Tii exhaust manifold with a little modification. It is a better part in that it will not crack and break after a relatively short time like the stock tii exhaust heat shield will. If the underhood appearance is more important than longevity, know that you will replace the stock part probably a half dozen times or more before the other part even begins to fail. Figure that the early part is easily cleaned/bead blasted and then painted. That's why over 30 years later these are still around!
