replacing front floorpans
Can anyone give me info in regards to cutting out the old rusted floorpan and welding in a new one...if I cut the floorpan away from the cross frame will it cave in, rise up,or stay static.I started cutting it out last night and then thought since its not connected in the back will it pop up or something,any info would be greatly appreciated.Thanks in advance.
cutting the floor away shouldn't make the car sag. If you want to be doubly sure, block the car with short lengths of 2x4 under the frame rails on each side just under the rear of the door openings before cutting. We did that on a Mustang convert before re-welding the floors; if we hadn't, it would have buckled for sure. (it was already sagging).
Your '02 (with caveats above) should cause no problems.
Cheers
Mike
get a couple equal length 2x's or such and a straight piece to cross from rocker to rocker. Stand the stubs up and measure down to both sub frame tail ends. WRITE IT DOWN where you won't loose it. Go ahead, ask me why. Also. You can cut the floor away and just leave the piece at the very end of the sub-frame. Mine was open for quite a while and when re-welding I just shimmed the sf up a little bit to equal other side.
