Hi, well I am now fumbling around with a TII that has been sitting a while. After fixing all the fuel leaks and draining the tank, I got it running. It runs pretty decent, lucky me. However I noticed fuel pooling in the air snorkel. So after reading the forums I figured the injector was faulty. I unplugged it and it ran even better. Since then I have tested the injector as the forum suggested. It seems to be operating as I would expect, just a Burst of fuel while cranking. So I plugged it back in. I notice the throttle plate (choke looking thing) isn't opening to allow the fuel to enter the intake. Should that plate open upon cranking the engine? Thanks fred
As suggested, I've always wired the cold start injector to a manual switch, hidden under the dash.  I'm in northern CA and don't need much help when its cold so I turn the ignition on, hit the cold start button for about 2-3 seconds and its good to go.  This eliminates common problems with the injector and/or thermo switch but is not a "purist" fix.  ;-)
Dan
