Emergency brake cable install problem/questions
I am in the process of installing new backing plates (seized rear adjusters!), new shoes, etc. and decided to go ahead and replace the e-brake cables while we were at it. The "internal" cables themselves are free (removed the nuts, etc) but I cannot pull apart the outer cable from the "fixed" outer cable (this is about 14" or so inboard from the backing plates). Any suggestions are appreciated! Thanks!
I have some PB Blaster but haven't tried that yet. I grabbed the metal piece where the "fixed" outer cable meets the more flexible part that has to be removed and pulled as hard as I could with some vice grips but no luck. Anything else?
I did this once a while ago, and I remember it being a real bitch to do, but I don't have any specific memory of having trouble pulling out the cable.
Are you sure you released everything from around the handbreak? If so and if it is still hard then I would probably just pull on it till something gave.
I used a flathead screwdriver like a chisel and drove them off with
hammer tapping. Just get under the car, place the
screwdriver against the plug, facing towards the rear of the car,
and tap it with the hammer. It should drive it out fairly easily. I
also spent a lot of time trying to pull or twist them out and
couldn't do it. Once I tried this with the screwdriver and hammer
it took almost no time at all.
I hope this makes sense,
Dave
