A ? for those w/ VDO oil press. gauges...
I found out about this after seeing it on a Circle-track car. I've always struggled with the plumbing for a mechanical gauge AND the idiot light sensor. Easiest way I've found up until now was to buy ($$) or make an adapter block for both the hose for the gauge and the idiot light sending unit. The "new" method is to simply use a standard brass "T" fitting screwed right into the back of the gauge, then screw the hose from the engine port into one hole and a generic sending unit into the other port!! SO simple it's ridiculous!
Bret.
p.s.- I have not actually done this yet, only seen it done on a race car. I am wondering if it might be necessary to make sure the sender is grounded somewhere for the light to work...(??)
