Catastrophic Steering Failure
Hey all,
I've recently purchased a 1973 BMW 2002 in seemingly good condition. Car drives great and I've had only minor  troubles so far. Ive had the brake boosters reconditioned, had brake lines replaced with braided lines. replaced fuel lines etc. No major issues or call outs so far.
This morning when maneuvering out of a tight parallel park I over exerted the steering and it seems like i catastrophically busted some bushing in the steering assembly. The steering now spins freely without moving the wheels at all. Photos attached.
To the best of my knowledge this is the stock ball joint BMW steering.
Seeking some feedback on the following.
  • General advice and comment
  • Best mechanics to send the car too for repair. (for those in Sydney, NSW)
  • repair/replace with stock parts? switch to rack and pinion?  upgrade to power steering?
  • Any ideas on indicative costs and effort?
My mechanical experience is pretty much limited to changing fluids and brake pads only, so apologies if my description is off.
post-46987-0-79097600-1397356615_thumb.j
post-46987-0-20224400-1397356634_thumb.j
post-46987-0-20376600-1397356651_thumb.j
post-46987-0-76854300-1397356667_thumb.j
post-46987-0-88502400-1397356682_thumb.j
post-46987-0-84600300-1397356692_thumb.j
Edited by Marcus Ashley
Looks like the steering coupler bushing disintigrated.
#4 in the illustration.
https://bmwmobiletradition-onlinecom.x-shops.com/bmw/showparts.do?model=ST11&mospid=47129&btnr=32_0971&hg=32&fg=30
Andrew Wilson
Lordy- do you bench press #400 on a regular basis?  That thing is tough.
I've never seen one die a natural death... did set one on fire once, tho...
There's a urethane one at Ireland, but maybe you want the stock one, as I suspect it's tougher.
Catastrophic for the steering assembly in that an event damaged the assembly to the extent that the entire unit is no longer functional or operational.
Definitely not a catastrophic life event or catastrophic for the car no.
The real painful thing is the nose of the car is now stuck jutting out onto the road. Unable to move past the car parked in front, and unable to move backwards without making contact to a pole. The street is narrow too so towing is going to be a bitch.
I'm wondering if they might have a shorter lifespan on RHD cars, due it being closer to exhaust heat.
Also, does it have a little heat shield on RHD cars, as it appears in the pic?  I didn't think that was on LHD cars.
Edited by KFunk
Bring a Welder
 I'm trying to figure out a quick-fix using some wood pieces and duct tape to restore just enough steering to push the car to a more reasonable location/positioning for towing .....
Anybody got a quick-fix idea ??
Cheers,
Carl
Edited by OriginalOwner
You can usually shove the wheels enough to cock them in the right direction, at least enough to push the car to a safe position.
Replacing that bushing isn't hard; although I've not worked on a right-hand steer, I suspect the parts are similar if not the same.
1987 E28 535is -- Buttercup
1974 2002tii -- Pretty Penny
1994 E34 M5 -- Horehund
2001 E36/7 M Roadster -- Shaggy
I broke mine also. New york city parking did it in.
Get a polyurethane one from an old VW beetle. Same part. Identical to the ones made specifically for our 2002s, but half the price.
for a quick fix wedge a piece of wood between the coupling to get them to engage temporarily. Under no circumstances whatsoever should you drive it like that.
http://www.amazon.com/16-5150-URETHANE-STEERING-COUPLER-BUGGY/dp/B00BYHFVHK
Oh, and good luck getting the old one out and the new one in. You'll be wrestling it for a while. Having a buddy helps. And don't install the steering wheel in upside down ;)
Ask me how I know.
1974 Grey European Market BMW 2002
1976 Yellow BMW 2002 "GOLDENROD" SOLD
1972 Yellow Austin Mini 1000
A bunch of Bikes...
Hi Marcus,
I would recommend BimerTech 9948 1310, guy who owns it is Matt, they are in Balgowlah, http://www.bimmertech.com.au/
Matt has always been very honest and fair with me and knows 02's well, his brother races one, he always has a good spread of cars in the workshop.
I would get him to fit a heat shield as well, I think you can still get them, try Jaymic in the UK, Rogers Tii in the US or Walloth in Germany for the shield and rubber joint. You can try bmw dealers in Sydney but they are very expensive, ridiculous mark ups, just like most other Aussie vendors, captive audience and all that. Long live the Internet :-)
Good luck.
