lower door moulding installation- help
can anybody tell me the procedure for installing this moulding? nothing in the repair cd, and i also would like to know the part number for the plastic clips that hold it on. my HTK cd is blurry on this drawing.
thanks,
robert
the plastic clips are two piece,they have a pin in the center that has to be knocked out to remove the old clip.Use a punch close to the same diameter as the pin.give the pin a sharp tap using the punch and a small hammer till,the pin is out.the clip will then pop right off.You could also use a drill. to install:push the new clip into the hole. With a small diameter deep socket give it a little tap to seat it into the hole then,using your hammer, tap the pin into the clip till flush.The metal clip on the rear of the door with the 5.5mm nut can be loosened enough to slide the rear of the new trim on.Line the rear of the trim up with the rear of the door then, kind of hook the entire length of the trim onto the bottom of each clip so you can still see the clips from above now,hit the trim firmly with the side of your hand ,it will snap right on.Now tighten the 5.5mm nut just snug . Good Luck......Danny
