Anyone in No CA cutting up a chassis tub for scrap? I need
front chassis clip for several fabrication projects (rack & pinion steering, Vintage Air in-dash heat & ac, and maybe a couple of non-BMW engine swaps) – much easier to work with a loose clip on casters than a complete car.
If anybody’s cutting up a car, I’m looking for a complete front section (door posts to nose panel) cut across the floor behind the door posts (ideally including the floor as far back as the transmission mount ears) and across the bottom of the windshield posts, preferably including a steering column and booster/master cylinder bracket.
DON’T need a heater box, wiring, front subframe, steering, suspension, brake parts, fenders, hood, etc. Rust & outer nose panel and/or door post damage is ok as long as the basic structure (cowl / firewall / inner fenders / frame rails / radiator support) is not collision damaged & is reasonably structurally sound, any year ok. Will pick up in Sacramento / Bay area.
basic conditions after going out there last Sat)- sorta hope most of those ultimately go to resuscitate complete cars that are otherwise terminal.
What I'm hoping for is that someone who is cutting up a car that was hit or is too rusty to rebuild (bad rear shock towers/trunk floor/rockers etc) wants as much of the tub hauled off as possible, and will donate the hulk in exchange for getting rid of it.
Whatever I don't have to spend on the clip moves me that much farther along on the fabrication projects......
with a sawzall.
Rather than chew up bandwidth, e-mail me offline either at the Yahoo address above or @ barry.allen@comcast.net and we can discuss what you've got, where you are, what's going to be involved transporting your shell, etc, etc......
