Texasyeti
Starting After R/ring Fuel Delivery System
2 posts / 518 viewsLast Reply
(edited)
I did search before asking. I swear.
Working through my new-to-me 74 tii. Brakes and front end almost done so while I wait on parts I moved to the fuel delivery system.
Tank looks great inside. I drained it, pulled the pick-up, cleaned the screen, and reinstalled with new rubber gasket. I have a new filter for the front end and correct rubber line where needed.
I dropped the pump / canister assembly and cleaned everything up.
Now I have two questions:
1. Should I prime the pump in some way or another prior to trying to start the car? I always thought it was a no-no to run an electrical pump dry.
2. Anyone know of a good source for an inline fuel filter? I want to put one between the tank and the pump as my pump does not have the inlet screen (replaced in 1995 with aftermarket)
I can find plenty of 1/2 inch inlet/out fuel filters. 12mm is not much smaller than that. Safe to use?
Edited by Texasyeti
1. Crank it up. Should Sifon fast enough.
2. Just go to the parts store and find a suitable filter. I used a hanging, top inlet/outlet piece and hung it under the car where the hose exits the trunk. Pump isojbted above the diff and little on down the line.
