Brake pedal height adjustment question...
It is not a hard job, but it is rather involved. You'll need access to both ends of the brake linkage rod, which necessitates getting to the pedal box (easy) and in behind the brake booster (not easy). There is a jam nut on each end holding the fork in place. You need to remove the spring clip from the clevis pin, pop the pin, and loosen the nut, then adjust the fork position on each end. Make sure you don't adjust it too far toward the end of the rod. It is a lot of trial and error to get it right where you want it. It is a fair amount of cramp-inducing labor on the engine bay side, so if you have other jobs to do in that area that will improve your access, now is the time.
