Fuel, timing, help!!! Running problems.
When I drive my 75 02 with a 32/36... If the choke is pushed in all the way, and I start to give it gas, it feels as if it is pulling, and not speeding up??? But when the choke is pulled out, I dont have this problem??!!
I adjusted the air/fuel to correct, and the timing is good so any other sugestions?? Like fuel pump??
Thanks
Nick
I started to say that it couldn't be the fuel pump if it runs okay with the choke out, but the choke restricts air flow, so it wouldn't need as much fuel to run. I guess its possible. It could also be fuel filter related or a vacuum leak.
The mix adjustment screw is only for idle mix. After that the idle jets, the main jets, then the air corrector jets. I just went thru a bunch of experimentation with the jetting on my 32/36, Email me if you need help.
