Sreedo and Tach conversion
Whats a hot set up for speed and tach conversion on a 2002 with 318is conversion.Cable to electric.What electronic stuff will go into stock dash or will I have to build custom dash.
Contact one of the folks that does VDO gauge repair (several advertise in the Roundel) and see if they can take the faceplates and needles from a mechanical 2002 speedo and install 'em on the electronic speedo guts from an E30, then stuff those guts into an '02 speedo housing. Same with the tach unless one of the electronics wizards on the board can tell you the tach will work with either engine.
Mike
