Dash Restoration
echappe
  • 2 months later...
It's hilarious how the top 3 search results from the above mentioned search leads to etsy telling people to search. How do these threads beat out the actual thread? For all the future google searchers here is a link to repair your own dash:
http://www.bmw2002faq.com/_/technical-articles/body-and-interior/dash-repair-r21
Not an o2 dash, but same idea:
http://forums.bimmerforums.com/forum/showthread.php?1865940-DIY-Cracked-Dashboard-Repair-Pic-Heavy
Edited by bazju
life's a circle
Just dashes is the only option, none of the techniques to fill the cracks will work (may work for while).  Or, you can buy new from BMW. I saw Kaptanoglu's (John)'s Werk shop restored tii at the Mid 2014 fest  and his dash was beautiful with all the letters silk screened and all.Very expensive. There are plastic caps that slide over the old cracked dash which look pretty good. You can have Fernandez (or Martinez) to cover the cap with ultra sued at a fraction of what Just dashes and other hi dollar places charge,
I got the plastic cap from JC Whitney, it is the quick, easy, relatively cheap fix, you can tell it is not the original dash, and the fit around the glovebox is a little tight and fiddly, but overall not too bad.  If you are going for the uber perfect original look 2002 I would probably go with a real replacement dash though.
Lincoln, NE
74 2002
68 Triumph TR250
Wow the dash cap looks great.
I had my dash repaired by a guy that works through FibreNew.  As usual is more about the craftsman than the franchise, but It cost about $250 and looks great.  I poked at the repair locations and it seems pretty tough.
any pics?
I'm surprised at that dash cap. I'm not looking for anything close to perfect, just something that doesn't have big cracks in it. Do I still need to trim down the cracks or does that cap hide it all?
 a little sending of old dash helps.
