draggin' brakes
bear with me here, i'm learning.
the rear brakes are dragging on my '72 tii, i replaced the wheel cylinders, but they still drag. would'nt the fronts drag too if it were a master cylinder poblem?
is there a way to check the lines?
thanks
zach
if you have not changed the flexible lines and you don;t know their origin, replace them. also chekc the adjustment of the rear brakes. They might just be a bit tight.
steve
thanks steve, i'll replace those lines. it's worth mentioning that if the car sits for an hour or so the brakes free themselves up, until they're applied again.
z
replace all 6 of them. stainless braided lines make a great upgrade, but you can stick to the ruber ones. they are cheap. get flare nut wrenches for that job, if you don;t have them.
steve
