Hi everyone. Stupid question: how do I remove the front
Paul,
Slide the seat forward a little, if needed, and at the rear of the front seat rail you will see a bolt, 10mm socket needed; slide the seat to the rear if needed and you'll see the same bolt at the front of the seat rail, to remove the seat itself from the rails, once the seat is out of the car look at the bottom of the rail itself.
Tim
The seat rails on my car (72 2002) and Phil's (70 2002)have a "L" bracket on the front and the bolt is actually on the front side. It might be under the carpet a little.
It is pretty self explanitory when you dig into it.
G
