One H4 Headlight Too Dim
Mitch_M
So over the summer I upgraded to Hella H4 headlights. I noticed the other day that the driver's side headlight is about half as bright as the passenger side. I've checked the relays to make sure the connection is good, and checked where the actual light plugs in. Any ideas on what could cause this? I wouldn't think the bulb would already be going bad, but that could be it. TIA.
+1 on the above advice, but please tell us what year your car is and if it has been modified with additional relays (if a Roundie).  You mention relays so I am guessing it is a 74-76.
Sorry, it's a '72 tii. I read on here that it was safer to put in a relay when upgrading to H4's. I'll swap bulbs when my classes let out for the day and report back then.
+ 1 on grounds.  Headlight grounds are a simple bolt/screw that's fastened to the body, in a location that's vulnerable to rust/corrosion.  Just trace the brown wire (brown wires are always grounds on 2002s) back to it's ground, then clean and reinstall.
