tii starts fine when cold but doesn't when warmed up
it starts on 1st try everytime when cold after warming up it
turns over, no problem but won't idle it just dies. Someone
mentioned a problem with the warm-up regulator but have no
idea. Thanks for the input.
is a piston looking thing in the back of the pump.
As water gets hot it expands a plunger, moving it
up. The top of the plunger has a big washer, when
it is down (engine cold) it presses against a lever
which in effect enriches the mixture. As it moves
up it frees the lever to its normal setting. So when
the car is warm there should be a gap between the
lever and washer. You can actually see this thing
move up as the car warms up. Make sure that the
car is actually reaching operating temp, there is
movement on the plunger and you get a gap. This
is in a nut shell.
Good luck
Michael
72 tii (Bacchus)
is working properly. More precisely, on starts when the
engine is warm, the motor will run for a few seconds with the
rpms going up to 1500-2k then immediately drops to 0 killing
the motor. Any ideas? thanks a lot.
This one is located next to the tuna can on top of
the throtle body. Just pull the 2 wire harness. It's
used on all starts and it is only supposed to last 8
secs max when really cold and about 4 secs at 65
F. It is possible that is stuck.
Most people bypass the system and install a
manual switch.
See if that makes a difference
Michael
72 tii
It is possible that it runs fine at first because the
mixture is enriched, but once it leans out it
becomes too lean due to a vaccum leak
somewhere. Carefully (with a fire extinguisher
handy) spray some starting fluid around intake and
see if it makes a difference.
I disconnected the cold start valve after warming the engine
up. Starts perfectly everytime but the cold start valve is brand
spanking new it's for a 320i though. So is there another
culprit up the line or the cold start is defective? thanks alot for
your help. Cort.
injector was disconnected? If that's the case either
the injector or the trigger circuit for the injector is
bad (Can't tell you which, but I would suspect the
control unit). The injector normal position is
closed unless is energized. There is an aluminum
box in the engine compartment, left side of the
firewall that is the control for the injector (probably
hidden by the airbox) Neither one of my tii's has
one, wonder why?, both have a manual trigger. If I
remember right, I cut the two wires, got juice on
one from the fuse box and ran the other one to
earth on the inside, I installed a push button in the
middle of the earth one to complete circuit and
trigger the cold start manually. You can actually
hear it (clicking sound) Beware that if you do this
your tii will not be "stock" "original" etc.
Michael
72 tii
From what your saying I should get a new relay or a sensor
as the cold start injector appears to be function as designed?
Stick with me as we're closing in on the solution. thanks, cort.
You can either get that aluminum control unit or
bypass it with the manual switch, it's like having a
manual vs automatic choke, your choice.
Electricals are weak on a 30 year car, so IMO the
simpler the better,
good luck
Michael
The start valve is controlled by 1) the Time/Temp Switch in the coolant hose manifold near the front of the head and 2) the Time Switch on the firewall. It's pretty easy to test these using the procedure in the Repair Manual, and it's easy to replace either unit or to repair the wiring. The main hurdle is the cost of a new Time Switch, if that is needed. I sell rebuilt ones for much less than new.
The start valve should fire for one second on a warm start.
