Don't try this at home kids . . .
So I was working on the car late last night, trying to get the timing set (again) after having screwed with a perfectly good setup. . .
So it seems I left a nice oily shop rag on the exhaust manifold. . .
Driving around, "what's that awful smell". . "wait why is there so much smoke coming from the engine". . .
"Shit, the rag's on fire. . ."
Fortunately the only damage seems to be the spark plug wires (they'll burn you know), the wire and hose to the windshiel washer, and my pride.
I've given myself a couple dope-slaps, so you don't need to bother. . . I think its time to buy that Halon fire extinguisher I've been putting off. . .
Cheers!
John N
I lost one of my nicest sports car due to fire, some
oil fell on the exhaust manifold and in 10 minutes
the engine compartment was toasted.
This one was a 89 Voyager, 2.2 liter, 5sp, short
wheel base, minimum interior. It really kicked ass,
very practical and fun to drive, I am serious!
Michael
72 tii
I just got a beautiful Halotron unit from MoonEyes in Santa FE Springs, CA. Their # is 800 547-5422.
The units are chromed and come with very trick aluminum brackets. You can get them in 3 sizes (1 1/2 lbs, 2 1/2 lbs, and 5 lbs) and can choose ABC powder (yuck!), Halon, or Halotron (the new replacement for Halon). They also have roll cage brackets.
I personally think anyone with an '02 (particularly a tii!) should have an extinguisher and I am a doofus for having waited so long! The final straw was a hose clamp failure that popped the fuel line off the filter and spewed gas all over the place...I got off lucky!
Best,
Coop
It had a bracket under the front seat for a fire extinguisher but no bottle. It didn't take me long to go and get one at the hardware store. It's a $20 insurance policy.
It was a comfort on last summer's trip to O'Fest. Not just for me but the other two tiis in my caravan.
My Dad told me that if you can't exit the car with the fire bottle in your hand, it's worthless.
Delia
set up that is cheap and easy to do. Home Despot sells mount brackets with quick release hold for the typical ABC fire chemical extinguisher( typical size: wait... 13 1/2 inches tall x 3 1/2 inch diameter ( just measured kitchen ext.) made by Kidde. I mounted 1 of my extinguishers to the recaro seat adapter bracket with just drilling small holes and using self-tap metal screw to attach ext. mount to the front of the seat bracket. It is not in the way ever, and it is easy to access fast. going to replace the ABC with Halon asap ( expensive!)so i dont have to go through cleaning process from residue of chemical ext. if i have to use it. i was taught a long time ago that an extinguisher is useless unless you can access it while you are upside down and hanging in the harness and in the dark( add creeping water to scenerio for pure agony). i also have a second ex. in the trunk cuz they only last about 12 seconds best with the size i use in the car. i see extinguisher mounts that a driver cannot reach from driver's seat and hope they never have the worst case scenerio. or always have a conscious pax to hand it to them.
