It Is Possible To Replace The Oil Pan Gasket Without Dropping The Subframe
Colin
...or raising the engine, for that matter.
I just loosened all the bolts and fished the new gasket down around the oil pump pickup and everything. Worked great.  The hardest part is removing the old gasket, but if you're cautious, its fine.
I've read all those links.  What I am contributing to the discussion is that I left the engine and subframe completely in place.  I did not lift the engine.  I just loosened the bolts on the pan and left it in place.
