E30 318 80 Amp Alternator
rover1
iv got the alternator but could anybody give a detailed parts list (bimmer part numbers) of the bracket, bushing, adjusting screw and other hardware required to complete a successful conversion for 2002. i know theres a ton of archival posts and articles but non seem to brake down the correct parts list. iv called a few of the parts vendors that advertise on FAQ and they have said that "some" of the stuff isnt available "new" anymore.
Basically, you will need everything on the E30 318 alternator mounting parts diagram. Maximillian's site shows all parts available. But the bracket is over $100! So find one used if possible!
Max's site: http://bmwmobiletradition-onlinecom.x-shops.com/bmw/showparts.do?model=1374&mospid=47315&btnr=12_0186&hg=12&fg=21
Part numbers: http://www.realoem.com/bmw/showparts.do?model=1374&mospid=47315&btnr=12_0186&hg=12&fg=21
Edited by Chamonix72
-David
1972 2002 - 2577652 Follow the fun
The same mounting hardware is used on S-14s, like the gold plated base mount one in the pic.  The mount bracket on the engine is the stock mount.  One of the other two brackets is for the air conditioner bracket, I don't know which is which, but suspect the repaired one is for the AC.
You might also put out a WTB feeler on an E30 board like E30Tech.com.  I've seen 318 discussions there, somebody must have spare stuff from an engine change.
post-9282-0-76779300-1390409219_thumb.jp
post-9282-0-45960200-1390409234_thumb.jp
