Breaks
Desiderio
I assume you mean that your Brakes are leaking, and you noticed this when you changed your tire.
Front brakes? or rear?
Is it the line that is leaking? or the caliper/drum?
Replacing brake lines is a simple job if you have the right tools and nothing is rusted. go with stainless steel brake lines. Ireland Engineering (bmw2002.com) or Blunt Tech (blunttech.com) can both set you up with what you need.
Leaking calipers means getting replacements. if the rear drums are leaking, it is the pistons, which will also need replacing. both are simple jobs.
1974 Grey European Market BMW 2002
1976 Yellow BMW 2002 "GOLDENROD" SOLD
1972 Yellow Austin Mini 1000
A bunch of Bikes...
