Can E30 Rear Subframe / Suspension Fit To Nk?
Bens
It's been done successfully. I know of one and the car is quick with the right setup. Definitely opens up the opportunity to use different gear ratios . I think the rear subframe just bolts in. Or it could be off an inch or so either side. I can't remember . Huff could chime in !
Rey
I'm a BMW Zombie and there's no cure!
Yup, it has been done…..with some proper adjustments and tweaks.
it was my way to get away from the long neck diff and opening up more gear
ratio options in the future / as needed. The diff is stronger..….and the addition
of LSD and rear disc brakes was a plus.
Feel free to message me through the board to further discuss.
Jim H.
