Almost Done W/ The 5 Speed Conversion, Help
king02
Go to solution Solved by king02,
So I have a 70 2002 4spd, doing the conversion, motor in, tranny in, 3.91 rear et al done too. My problem is that the drive shaft and 5 speed were in another car, I purchased it for my conversion. And upon putting in the driveshaft and guibo...IT IS TIGHT. TOO tight i believe. ANY SUGGESTIONS! One suggestion was to grind the guibo metal guides 1/16 on both sides to give an 1/8 of an inch. How much slack or play should  I expect.  Appreciate any feed back.
70 2002, 74 2002 track car, 98 M3 sedan
before grinding the guibo, i'd check the axial position of the engine within the engine bay.  ditto on the differential.  there's about an inch of forwar/aft movement on the differential.  maybe your engine can move forward a bit.  if the fan is not hitting the radiator, that is...
& 1 special alfa
As they said, loosen the six differential bolts. Slide the diff back in the carrier. Mate up the guibo to the flange. Tap the differential forward with a hammer and a wooden block and tighten the bolts. Do the guibo-to-transmission-flange-alignment thing as per my recent blog post.
1972 tii (Louie), 1973 2002 (Hampton), 1975 ti tribute (Bertha), 1972 Bavaria, 1973 3.0CSi, 1979 Euro 635CSi, 1999 Z3, 1999 M Coupe, 2003 530i sport, 1974 Lotus Europa Twin Cam Special (I know, I know...)
  • Solution
Touche', much better after loosening the differential bolts. Preliminary run upto 40 mph...thats pretty good since she had been dormant for 4 years or so!  Thanks for the three O2 amigos. Need a couple of shake down runs, any suggestions to cleaning downdraft 38s or additive to fuel (93 leaded..the real stuff), hoping the carb will clean as i drive.
