Leaking Oil Pan
Stevenc22
I might have set a record. I have officially changed the oil pan gasket 6 times in 6 months. I simply cannot get a good oil free seal. I have tried black RTV, Grey RTV and cork gasket along with combinations of both and have had no luck.
I always clean the mating surfaces properly, have sanded the oil pan mating surface and i still get tons of oil leaks.
I'm considering buying a new oil pan but mine does not appear to be warped.
Any thoughts on the matter?
Here is a thought....if the pan bolts have been overtorqued in the past, the bolt holes will deform and the gasket will likely never seal.  Next time you have the pan off look at the holes along the perimeter of the pan. The sheetmetal should be flat on both sides of the bolt hole.  If the sides of the hole appear "pooched out" (for lack of a better term) on the gasket side, they need to be re-flattened.  Lay the sump on something hard and flat.  Take a socket that will fit between the side of the pan and the raised edge and with a gentle tap or two of a hammer on the socket, flatten the sealing surface of the pan.  Do not overtorque the bolts on reinstallation.
Earl
74 02Lux
02 M Roadster
72 Volvo 1800ES
74 02Lux
15 M235i
72 Volvo 1800ES
People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." -- George Orwell
 Because the question needs to be asked for perspective:  are you certain it is actually the pan gasket which is leaking, that is, can you actually see the leak path(s) around the gasket ??
That interface is not necessarily a pressure interface, but I see it as a high vibration interface:  considering the weight of the pan and the physics of holding it in place during operation, one needs a very tight "grip" at the interface so nothing moves and thus creates leak path(s).  Hence the large number of bolts holding it in place.  If the pan is wiggling/sliding around during operation, I'm thinking the RTV will eventually break free and the leaks will begin.
So as has already been mentioned above, I'll guess the pan is warped.  This could be the whole thing twisted side-to-side, or you've got a couple of places that are not "flat" in relation to everything else.  And the warpage or "unflatness" could be such that the bolt(s) doesn't pull that area into flatness and proper seal.  Or the bolt(s) vibrate loose creating a leak path.
Washers:  I suggest using big washers under each bolt head to spread out the hold-down force and help prevent wiggling/sliding.
RTV.  I've never used it.  I was raised using Aviation Form-A-Gasket and had good luck with it.  Maybe you will too ??
OH, it just occurred to me after reading TobyB above:  maybe you've got a crack in the pan itself ..... or multiple cracks ??
Cheers,
Carl
Edited by OriginalOwner
Earl
74 02Lux
02 M Roadster
72 Volvo 1800ES
Earl has it right.  It takes more than a gentle tap, my ears were ringing, so I used a small socket and a vise grips to draw the holes back.  Once flat, no leaks.
You are limited in the size of washer you can use and still fit in the channel.  OEM Oil pan bolts can come with a captive washer but early cars don't come with them.  Most likely as everyone else has mentioned the holes are dimpled and you just have to get everything flat.  A nice piece of steel bar stock the right width that fits in the channel is a great thing to back up one side while you hammer the other.
Mike Katsoris CCA#13294
74 InkaGangster 4281862
76 Estorilblau 2740318
