High-Beam Indicator Mystery
Ferrance
First of all, are the high beams themselves working?  They should go on by themselves by pulling the low/high beam stalk, and go on in place of the low beams when high beams are selected.
Didja mess with the wiring at the stalk?  IIRC the dashboard high beam indicator light gets its power at the high/low beam stalk, so merely adding a relay to the high beam circuit shouldn't cause the indicator light to quit working.  Presume you installed the relay somewhere near the voltage regulator where the high beam wire runs between switch and headlight.
Could be bulb be burned out?  Funnier coincidences have occurred...
cheers
