Close ratio 5 VS. 5 spd Overdrive
and on the motor you have.
Do you a 10.5:1 schrick 316 8000 RPM car that sees a lot of track? Then go close ratio.
Is it a stock daily driver? Then go overdrive.
A close ratio 5-speed has a 1:1 5th, which is the same as 4th on an overdrive, (or a 4-speed.) An overdrive will drive just like the 4-speed except that you get an extra cog for cruising and fuel economy.
What are you planning for a diff?
If you are racing but cannot find a CR, then an OD tranny with a 4.1 or 4.4 differential willl be just as good. The higher diff will give you more pull at all gears except in 5th OD.
If you find a CR, hopefully it is one coming from a 320i, it is stronger and more available than one from a 2002.
They do not have the same mounting bolt pattern. In your case (M20) you need the tranny from a Euro 323i with the mechanical speedo drive gear. An e30 325 tranny doesn't have that speedo drive, as the speedo is electronic.
You spend a lot of time "stirring the porridge," and it buzzes at higher speeds (same ratios as the stock 4-speed in top gear), but it feels quick, and there are no "dead spots" while you're waiting for the engine to spool up after shifting gears. I'm very happy with the combination.
The 5 spd CR and 40%3.64 LSD has a cool nostalgic feel to me that I like. However, in most situations I feel that I can drive the OD car faster.
I am sure that it has something to do with the parts availability. Knowing that I can pick up an OD for 300-400 bucks allows me more freedom.
But, it depends on what you want it for. My 2 cents is the OD and 3.91 for your car.
HTH,
-Jason
