32/36 dies when I open the Choke.
I got my 75 running. I let it warm up, The go an disingage the choke. It sputters and dies. can some one suggest something to check. I already looked for air leaks. and found none.
Thanks
Andy
screws backed out? The choke acts to restrict the air intake and make the mixture richer.
If your idle adjustment screws are out, you need larger idle jets.
Cheers!
John N
Also, remove the idle jet(s) and check to make sure there isn't a piece of dirt plugging the orifice, which is often the reason for failure to idle with the very small bore idle jets on the 32/36.
I had the same problem, I did everything including re-building the carb, it would run great till the engine got warm and then it would sputter adn die.Cold and chocked it was ok, warm and open it would die.
To fix mine, looking at the carb from the right fender on the right side towards the front there is a prong that needs a wire attached to it. This lead needs to come from the coil or battery. This little switch is to prevent run on.No power it will shut the flow of fuel to carb....with powerit works. I hopr I did not confuse this to much.
Joe
