camshaft i.d.
does anyone have a source for camshaft i.d. markings. i am interested in a bmw M10 camshaft with stamp "2107" ( they think it is a 300 degree cam)but i cannot find any way to i.d. it on the web, and i am away from my resource books right now. any leads appreciated. thanks
Manual says stock camshaft has Ø 35 ÷ 42 ÷ 43 mm. base circle = 27mm, camlift= 7,0267mm
A 300 need acording to parts cat. rebore so I guess its not a 300 :(
You must be looking at the Bekkers Import M10 cam from their display case. I can't believe they would say it "might" be a 300 sport cam, it is pretty simple to check with the published info from BMW.
It is definately NOT a BMW Sport 300 degree cam.
ALL of the dimensions given indicate this is just a stock cam. The big difference is the journal size (300 cam has increased diameter on two of the journals & requires line-boring of the cylinder head.) That, and the lift they report is very slightly under stock, which is probably just an error in measurement.
