Four Bar "cage" On Heater Box
BillWilliams
Bill - my two early heater boxes (smaller heater core and valve) are different than my 73.  The motor will not interchange between the two top portions and the early box uses a larger protective "cap" for the motor itself.
The plastic "grille" of the box top is also different along with the motor securing clips
The early motor also has (2) spade terminals that are closer together rather than on the outer edges of the motor.
Pics added
Not sure when BMW (Behr) starting adding these directional vents to the floor outlets. I believe this heater box was removed from a 73 (not 100% sure)
Edited by jgerock
