ireland sway bar=money well spent (long)
Just finished the install (easy) and went for a shake down
cruise. Amazing what a little piece of tube steel will do for a
car. Prior to the install the nevada had an oversteer bias. I
had to muscle the car around corners and stay on the gas or
it would plow pretty hard. Don't get me wrong-it handled
pretty well but needed help. Now it's far more balanced and
stays way more flat in corners, curves, etc. I can brake way
later and carry far more speed through corners that I know
well. I had to adjust my driving of course because now it
takes less input from the wheel to get into the apex. I found
myself cutting the corners a bit short at first.
Overall, I opted for the softer suspension, stiffer sway bar set
up. I have cut stockers, new Boge (I give BMW credit for
knowing their cars, and specing accordingly) in front, Bil HDs
in back. In front is the new Ireland bar and in back is some
sort of heavier bar with rubber. So far so good. It's fairly
compliant on the road but stays flat in corners with the softer
suspension keeping the tires in contact on irregular surfaces.
I read about the 510 guys doing similar things suspension
wise-obviously nothing new here, but I wanted to avoid the
feel of my last Tii which had the traditional go fast set up-
Urethane everything, big bars, Eibachs, and Bil sports. Great
on the auto-X but a killer (on the back) on the street. The new
set-up I have now should run at about 9/10ths of that old
setup on the track, but maybe even better on the street. I will
add urethane bushings to the back bar as I noticed a very
slight feeling of the back end being dragged along by the
front-nothing drastic, but needs to be tweaked. I also need to
adjust the bars on front to the top hole instead of the lower. It
tends to remove camber I found.
Overall I give the fit, finish, and handling improvement a big
thumbs up.
