Distance Rubber For Seats - How Many?
seattle2002tii
Quick question - how many distance rubber pads (#15 in diagram) are required for each seat?  Does each side of the seat get this rubber pad?  So 4 total for two seats?
Isn't clear from diagram.  My seats are missing the pads and there is a lot of play / movement in seat back, but most of the play is on the outer side, so thinking maybe only install on adjuster side?
Thanks for any help.
post-43259-0-14586100-1387929645_thumb.j
There are only 2 listed by Max 10.29 each, readily available.
Edited by adawil2002
Andrew Wilson
I believe there are two per seat...one on each side as there are two pads that support the seat back when it's in its normal position (i.e. not tipped forward).  They're primarily to prevent metal-on-metal rattling, so if you're offput by the price, you can use a piece of rubber glued to the bottom of the seat cushion bracket.
cheers
