Doors Don't Like To Shut Right
glemon
Go to solution Solved by glemon,
My doors close, but loosely, they shut, but not to the final click unless I really slam it firmly and don't let it bounce back.  Have read a little bit about it in the archives, which mostly talked about replacement seals causing the problem but not much about a solution, other than they sometimes settle over time, I think I have replacement door seals, but they have been on a while, any fixes other than futzing with the striker plate? (which I have tried already a few times) I think it is worse now in the cold (stiffer seals, presumably).
Edited by glemon
Lincoln, NE
74 2002
68 Triumph TR250
The latch mechanism may be sluggish.  Open the door.  View the door mechanism.  Turn the mechanism as it would be to latch the door.  How operate the handle.  Did the latch open quickly?  If not you have a project to remove the mechanism, clean, relube and reinstall.
You may also be missing a small rubber tip that goes on the latch finger end, which moves the latch when the door closes to make the catch work.
Edited by jimk
Do you have these on the latches?
$1.95 at Bav Auto, Blunt probably sells it for $.95.
Part #51 21 1 809 735 Door Latch Buffer
it goes on the end of the door latch......
sorry don't have a picture of that handy.  just go to realoem  and look up the part number.  diagram shows where it goes.
or search on forum for door latch.  here is just one of the many threads on this....
http://www.bmw2002faq.com/topic/130942-door-adjustment-advice/
Edited by mlytle
3xM3
  • Solution
I had already looked at the link in the prior thread, which wasn't much help, as it went to a main page, then looked at the parts diagram on the Penske Parts page, which also wasn't much help, then looked at my car, and figured it must go on the u shaped thing that goes around the post mechanism that holds the door shut, on the side with the two detents to hold the rubber piece in place.  Then I saw Original Customs pic, which confirmed it, nope haint got nothing like that on my car, will order a couple would think it would do the trick of getting the mechanism to go far enough to lock by the looks of it, should be a cheap and easy fix.   THANKS.
Edit: Ordered a set on Flea Bay, a couple quarters more, but free shipping, seller tilux (nice name) is this anyone on the forum?
Edited by glemon
Lincoln, NE
74 2002
68 Triumph TR250
Those missing little "door latch buffers" are definitely the cause of the problem that you describe.
It's happened to me a number of times over the years and replacing them did the trick every time.  The first time, I was very surprised that such a little part could make such a big difference, but it did.
Regards, Maurice.
Edited by schoir
yes Tilux is a member here and a good guy.
www.BluntTech.com
FAQ Supporting Vendor
 Sales@BluntTech.com
While you're waiting for the little "corn kernels" to arrive, you can substitute a little piece of plastic or rubber hose (like fuel line) slipped over the inner leg of the u-shaped latch.  They work just as well as the factory part, just aren't as asthetically pleasing.
Also--quick and dirty way to lube the latch mechanism without removing the upholstery panel:
1.  drizzle a little light oil around the rotating collar that the U-shaped latch is attached to
2.  remove the two screws that hold the trapezoid-shaped rubber buffer, take a WD40 can and bend the nozzle down at its end.  Insert through the screw holes and squirt.
The WD40 will at least soften the 40 year old grease and grunge on the mechanism and make it work a little faster until you can take the door apart, remove the latch assy and soak it in degreaser/kerosene/carb cleaner and re-lubricate.
cheers
  • 1 month later...
I was pretty skeptical about this actually working for a few bucks. Ordered them from the dealer and sure enough those little bastards did the trick. No more slamming my doors, they shut so nicely I don't feel like I'm going to break the glass. I'm a believer. This actually worked.
Your username cracked me up.
I always yell "get to the choppah" whenever a helicopter flies overhead.  Most don't get the reference and just look at me like I'm crazy.  Which is partly true, anyway.  ;)
'84 323i Euro Edition
'85 325e (parts)
'14 328i Sports Wagon
'69 2002 Chamonix
