Any estimates on complete brake rebuild?
I'm interested in purchasing a '74 2002 which is in great shape except that the owners say it needs a complete brake rebuild. It will go about 15 miles before the brakes get hot and lose some of their functionality. Any ideas of costs or what needs replacing based on those symptoms? I'm pretty handy but not sure if I should take my life into my hands by doing this myself... Any ideas. Thanks!
Pads, shoes, drums (assuming they need to be replaced), rear wheel cylinders, brake lines (rubber ones in front), about $200 in parts. If you have to get into the master cylinder its easier to replace than to rebuild, but you'll pay more (about $100 or so). 9 times out of 10 the calipers are okay, but if not you'd probably want to rebuild it or find a good used one.
Plus DOT4 brake fluid and a six pack of beer.
If the adjusters are frozen (as they are on my rear drums) you will most likely have to replace the backing plates as well. I ordered used ones from 2002AD at $25/each. You also might want to replace the emergency brake cables. Good luck.
